Released April 2019, identified by model numbers SM-A205F/DS, G, G/DS, GN, GN/DS, U, U1, W, YN.
49вопросов Показать все
Why does my charging port smell like its burning?
why does my charging port smell like its burning and what do I do to it? are there solar or wireless chargers compatible with A20 available on amazon so I dnt’t have to plug it in?
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Dayshanelle Squire the Galaxy A20 doesn’t have wireless charging. So no matter what you will have to use the charging port. Check it for any debris by cleaning the port with some drops of high-grade isopropyl alcohol and a few puffs of compressed air (Air-in-a-can will work) After that, you will have to disassemble it and check the connections on the charging port to the board. Personally, I’d go ahead and replace the charging port connector (board) just to make sure. Something like this video will help you with that.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Dayshanelle Squire будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 2
За всё время: 57
