Garmin's Forerunner 55 Battery Replacement, is it possible?
I’ve just realized that my recently bought Garmin Forerunner 55 has no apparent way to replace it’s battery.
Am I wrong?
Это хороший вопрос?
Счет 2
Добавить комментарий
1 ответ
Наиболее полезный ответ
In theory it should be possible, but just by what I can find on it online it’s going to be difficult to replace. Just by looking at the device I can already tell you’re going to need an opening pick and maybe a heated device to soften any glue holding the screen in place.
Although, assuming that you can get into the device then you’ll need to find a replacement battery. I couldn’t find a new one online, but I’d be willing to bet if you contacted Garmin’s support they would put you into contact with their battery supplier. Otherwise you could maybe cannibalize an old Garmin for its battery.
No more adhesive battles! With our iOpener, you can quickly and easily remove glued components in electronic devices whether you're a repair professional or beginner. Apply gentle, even heat to loosen the adhesive holding smartphone, tablet, and laptop case components and batteries. Изображение
Товар
iOpener
$24.99
Был ли этот ответ полезен?
Счет 2
1 Комментарий:
So to give you the Spark Notes of it. Is it possible, yes. The question is, is it worth it?
из
Добавьте свой ответ
Fernando Alves Reisen буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 18
За последние 30 дней: 97
За всё время: 3,297
