The PlayStation 3 (or commonly known as the PS3) is the third home computer entertainment system produced by Sony Computer Entertainment, and the successor to the PlayStation 2. It was released November 11, 2006
720вопросов Показать все
Ps3 turns on but I get a 480p grey screen
I'm working on this ps3 that has a ylod but I cycled it a few times and now It turns on and I get display but just a grey screen at 480p. I did do a gpu reflow which got it to turn on and stay on now but before I wasn't getting display. Do you think the gpu is bad and is their something else I could check. Iv heard changing the caps on the back can fix a ylod of death.
Это хороший вопрос?
Оценка 0
Комментарии:
Update I just got display and sound
из
@pendragon1 Glad it's working now. If you get the YLOD problem again and you want to try replacing the capacitors, you can check out the PlayStation 3 Permanent YLOD Fix guide.
из
@andrewsawesome thank you, I still have to add a little pressure to the gpu to get it to turn on then cycle it a few times before I get display. Would a reflow help this or is the gpu going bad
из
Добавить комментарий
1 ответ
did you try to change the hdmi cable
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Pendragon будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 2
За всё время: 23
