help did I get scammed?
So i bought this thinking i could fix one of my other ones,
Anyway when it arrived, i plugged it in and nothing,
I thought something was unplugged inside, so I took it Apart nothing was unplugged,
So i tried the keyboard on one of my other laptops, still nothing Nothing
What the heck is going on?
@danj
Это хороший вопрос?
Оценка 0
2 Комментариев
What does the onboard battery checker tell you?
из
@danj - By nothing i mean it does nothing at all (black screen, no lights, no fan speed)
из
Добавить комментарий
Ответов (1)
Выбранное решение
There is a onboard battery checker within the battery. locate the LED's and the small button on the battery. What do you get?
The charger plug also has a Green or Amber lit collar. Is it lit and what is the color?
If both are dead then you will need to get replacements to check things.
Был ли этот ответ полезен?
Оценка 1
20 Комментариев:
I got no battery,
The charger has a green light
из
@beanman56 - OK, this series needs a battery to run. I would also replace the PRAM battery MacBook Pro 15" Core 2 Duo Models A1226 and A1260 PRAM Battery Replacement But how much are you willing to put into this system? What is your expectation?
из
@danj - A decent macbook for media,
Also i like the keyboard design,
Would a 2007 macbook (NOT PRO) battery work?
idc if the matches
из
@danj - where can i get one for a cheap price?
из
Показать 15 больше комментариев
Добавьте свой ответ
Ben Capehart будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 1
За последние 30 дней: 8
За всё время: 207
