Don’t turn on
does not turn on. I tried all combinations with the power button but the computer does not respond. when I get off the charger, then the charger heats up as usual, but the computer itself does not react
Это хороший вопрос?
Это хороший вопрос?
Try the SMC reset on the mac,
https://discussions.apple.com/docs/DOC36....
If you are comfortable with taking the back off unplug the battery and plug it back in. and try start it again with the charger plugged in.
if this doesn't work you can try plug it into the charger and start it without the battery plugged in.
Был ли этот ответ полезен?
unfortunately does not help
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 10
За всё время: 265
Have you spilled any liquid, dropped it, or any other damaging things lately?
из Benjamin Dover
no, absolutely nothing like that...
из Irakli Kvirkvelia
Have you tried replacing the battery?
из guardian10
I doubt it is the battery as it don’t power on with the brick and it is only 2 years old.@guardian10
из Benjamin Dover
haven't tried it yet@guardian10
Показать 1 больше комментариев
