Why did my keyboard stop working?
I recently replaced the dc and sound board, and upon reassembly the keyboard didn't work. The trackpad works fine. How do you know if the keyboard or the logic board needs replacing?
Это хороший вопрос?
Оценка -1
2 Комментариев
Did you tape the the keyboard plug to the motherboard? This helps it stay in place.
из
If one of these answers fixed your problem please hit the "accept" in list that has "History Edit Flag Accept Comment" located to the upper right of your question so we can remove it form the unanswered list.
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
You probably don't need to replace it, most likely you just accidentally disconnected it. You should open it up again using this guide, and see if anything's loose or disconnected. Pay careful attention to step 13.
Был ли этот ответ полезен?
Оценка 2
Добавьте свой ответ
Charl будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 647
