Why my battery is too weak
Это хороший вопрос?
Hassan morray Koroma the battery is pretty much the only strong point on this phone. You should explain to us what you mean by the battery is weak. If you need to extend your battery life use the suggestions from here The battery life is only as good as you use it. The more you use it the shorter it gets.
Был ли этот ответ полезен?
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 7
За всё время: 486
3 Комментариев
My battery is so weak
из Dore Mone
Mere mobile ki battery ki life dheere dheere Kam Ho rahi hai
из Md Azad
not charge up properly/long enough
из antonio
