Optical Drive doesnt work
I keep getting an error message when trying to burn a disc from iTunes. Something to the effect that the disc is not recognized. Then the cd gets spit out of the machine. Took it into a mac store and they said we needed a new optical drive. I'm looking for a suggestion for which drive to use. Thanks
Это хороший вопрос?
Оценка -1
Добавить комментарий
3 Ответов
Выбранное решение
You can get this one.
Был ли этот ответ полезен?
Оценка 1
Наиболее полезный ответ
The optical drive may only need a laser lens cleaning. Before buying a new one you could take it out of the machine, open it, dust it off with compressed air and clean the laser lens with isopropyl alcohol.
Оценка 3
2 Комментариев:
Aren't there like cleaner disks too you can stick in there?
из
Sure but manual job is always better.
из
Gentlemen..thank you both for your responses. I've sent a disc cleaner thru it several times..still does not work proper. I'll look into the drive you suggested. Thanks again.
Оценка 0
Добавьте свой ответ
Glenn будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 946
