Hi,
Just verifying that pictures taken using the camera and then downloaded and viewed on a computer are OK i.e. no lines on image?
Not sure if you meant this when you said "everythings else seems to be ok."
If they are OK, maybe double check the connections from the LCD display to the control board behind the screen and also the cable connection to the control board from the camera. Also that the flex cable ends are clean etc. Try not to handle the part that goes into the connector socket with your fingers.
Here's a video that may help.
Был ли этот ответ полезен?
Проголосовали
Отменить
Оценка
