Released by Dell around 2009, the E2310H is a 23-inch monitor with a resolution of 1920x1080 pixels.
4вопросов Показать все
Display gone red along with dead pixels and flickering.
My display has turned red. The lower part of the screen is flickering at a very high rate. Also, there is a patch of dead pixels on the left bottom edge of the screen. How do I fix it??
Это хороший вопрос?
Оценка 0
1 Комментарий
RANSOM just to verify, your display is a Dell E2310H? Post some pictures with your QUESTION of what this all looks like. Right now it sounds like a bad panel but we'll have to see. Adding images to an existing question
из
Добавить комментарий
2 Ответов
Наиболее полезный ответ
Hi
I usually work on apple products but I can try and help you with this
Here’s what to try:
Try plugging it in to a external monitor and seeing if it does the same thing if it does it will need to be further tested ,however if the external monitor looks normal you may need to replace your laptops screen
If you can provide me with photos I will give me a better idea of the issue but it’s most likely what o talked about above
Был ли этот ответ полезен?
Оценка 1
Well I am not an expert on this but this might help you.
  1. Turn off your monitor.
  2. Get yourself a damp cloth so that you won't scratch the screen.
  3. Apply pressure to the area where the stuck pixel
  4. While applying pressure, turn on your computer and screen.
  5. Remove pressure, and the stuck pixel should be gone
Оценка 0
Добавьте свой ответ
RANSOM будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 26
За всё время: 640
