Mid 2009 Model A1278 / 2.26 or 2.53 GHz Core 2 Duo processor EMC 2326
744вопросов Показать все
Component missing from motherboard
Good afternoon. Need help identifying a component that has deteriorated due to oxidation on the board. There were two faulty components an inductor and a component that appears to be a transistor but is very small.
There are other similar components on the board, but I can't identify them.
The first image shows the location of the component, very close to the coil that is damaged:
Here's an image of the component similar to what's missing:
The rest of the board seems to be ok, just missing this to revive this monster!
Thanks to anyone who can help!
Это хороший вопрос?
Оценка 1
Добавить комментарий
1 ответ
Выбранное решение
wagner.m.v that is reference designator Q7800 which is a SSM3K15FV N-Channel Mosfet in a SOT-723-3 package.
Был ли этот ответ полезен?
Оценка 1
4 Комментариев:
Thanks a lot for your tip.
I ordered the part, as soon as I make the exchange I will let you know if it worked!
из
Looking at your image I realized that maybe more components are missing, can you help me identify them?
из
@wagner.m.v sure we just need to have some good pictures and markings as where do you think the components are missing or damaged.
из
friend, I made a new post with a good photo!
Components missing in an area of ​​the board
Thanks!!
из
Добавьте свой ответ
wagner.m.v будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 78
