The Razer Blade Stealth (2016 model) is a laptop designed specifically for gaming. With an Intel Core processor giving fast speed yet smooth, crisp graphics.
System shut down as soon as I unplug
I have a Razer Blade Stealth 12.5, and I just bought the Razer Blade RC30-0196 Battery since my original battery dies very fast. I replaced the battery and the system can detect the new battery, and charging is good. However, when I unplugged the power adapter, my laptop shut down immediately. I think this might be a software problem, but after reinstallation of battery driver it still didn;t work. Anyone knows how to solve this problem?
Это хороший вопрос?
Оценка 3
Добавить комментарий
Ответов (1)
Наиболее полезный ответ
Hi @dx7676,
You may have got a faulty battery.
Create a battery report and check the Full Charge Capacity value versus the Design Capacity value. For a good battery they should be nearly the same values.
Был ли этот ответ полезен?
Оценка 2
3 Комментариев:
Hi @jayeff ,
I just replace a new battery from iFixit. When fully charged, the capacity of this battery is 49873 / 51790 mWh (design capacity). I believe it's almost the same.
из
@dx7676 See if the advice here helps you:. razer support page.
из
@dx7676
Have you still got the old battery to reinstall to see if the problem is still there or not?
из
Добавьте свой ответ
Steven будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 2
За последние 30 дней: 9
За всё время: 774
