Can faulty iPad damage LCD panel
Hi, I have purchased a non functioning iPad for parts, as I wanted the LCD panel and digitiser and was told the LCD was still good.
After removing these and going to install in another iPad I discovered the LCD was completely dead. This was a little annoying, but I am now wondering if the iPad is still good.
If I was to put a new LCD in to test it, is there any chance a faulty iPad could damage this new LCD? I am thinking maybe a faulty board could send too much power and kill the panel?
If the answer is yes, can the connector be tested easily by a professional without installing a panel? Or is there a simple way to do this myself with a multimeter?
Thanks
Это хороший вопрос?
Hi, did you disconnect the Battery before you disconnected or connected the LCD? If not the Backlight filter or coil could now be broken.
из Spaeder
Hi, yes I am always very careful about that.
I can see a repair has been done previously, it looks like maybe a charge port replacement, so am thinking either they weren't careful when disconnecting/connecting LCD, or board got damaged which may have in turn damaged LCD?
из Chris Reader
