battery will not charge after water damage
So my iPhone 2g got rained on a week ago and it powered back on after i immersed it in rice but not too long afterwards the WiFi went off and turned grey in the settings, and so did the network. The phone lights up when connected to the computer or charger but it is stuck in low battery charging mood and wouldn't even charge or boot. I have taken the phone apart and i noticed that the battery is a little too soft for my liking. My question is how do i know if the battery is damaged? when i press the battery it feels like it melted. Is the battery rock hard when it is not damaged? Also how do i fix the issue of the WiFi and network signal not working. Any help will be greatly appreciated.
Thank you
Это хороший вопрос?
3 Комментариев
rice theory is a myth all you can do is immediately remove battery remove mother board and clean the board with isophrophyl alcohol best you can and hope for best
из pwruzr0202
or if all is working it is still advisable to clean board with alcohol since I have seen water damaged devices work a whole day and the next day they are dead this is what a repair shop would do as a first step or they should anyways the alcohol not only cleans any sulfur and oxidized surfaces but also evaporates quickly
из pwruzr0202
and ya a new battery goes without saying you will deff need to replace it..
из pwruzr0202
