Прокрутите эту тему, чтобы найти подходящее место для этого комментария. Затем нажмите "Прикрепить комментарий к этому сообщению", чтобы переместить его.
4 Комментариев:
Hi,
Have you tried using another known working, network compatible, nano size SIM card in your phone?
Have you tried using your SIM card in a known working, network compatible nano size SIM card slot phone to see if it worked there?
Basically swap the nano size SIM cards between two same network phones i.e. your phone and another one and check what works where.
Did you put a SIM card into the phone? A pin must be pushed into the bottom left side hole to eject the SIM card holder. Place a SIM card into the holder, reassemble the holder into your phone and turn it on. No SIM card, no phone use possible except for emergency calls.
Hi,
Has the phone been dropped at all?
What have you tried?
из jayeff
из F Dryer
@jayeff the phone dropped all
из Dickson Kaema
@dicksonkaema
If the phone has been dropped, the systemboard may have been damaged. The phone will have to be opened to find out what's wrong
из jayeff
