The Volkswagen Beetle was a compact car produced by the German automaker Volkswagen. It was introduced in 2011 as a successor to the New Beetle.
9вопросов Показать все
A/C heater vent in center dash closest to driver won’t blow air out
Three dash vents blow air out but one in center drivers side will not blow air out?
Это хороший вопрос?
Оценка 0
1 Комментарий
Hi,
What is the year model of the vehicle?
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
That's a common problem with the New Beetle. The dash vents are connected internally with a rod that has a ball on each end. That ball snaps into a holder, and it's unfortunately all too easy to use a little too much force on the dial and cause the ball to pop out of its socket, rendering the control knob useless.
The two outer vents are easy to fix; you can just (carefully) pry them out, but the center vents are plastic welded in place. The only way to get to those little rods on the center vents is to pull the console. You'll need a T20 Torx driver and a set of VW radio removal tools to do the job. I've heard that the straight metal hangers for hanging file folders work pretty well in lieu of an actual radio tool though.
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
Lynda Bartley будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 4
За последние 30 дней: 10
За всё время: 105
