Портативная игровая консоль производства Valve, выпущенная 25 февраля 2022 года.
250вопросов Показать все
Dropped Steam Deck - Broke Left Daughterboard
I dropped my steam deck and the LB quit working. It appears I broke the little blue piece that the LB makes contact with to produce the clicking noise. So I believe I need a new Left Daughterboard, which iFixit does not sell. I have attached pictures, sorry for the quality. Valve has still not gotten back to me after a couple of days. Can anyone verify that I need a new daughterboard? Does anyone know how I can get one? Or does anyone have any experience/advice with this? Any help is welcome. Thanks for your time. I'm beginning to worry there isn't a fix....
Это хороший вопрос?
Оценка 5
Добавить комментарий
3 Ответов
Наиболее полезный ответ
it just needs the button replaced, you would need to get someone to be able to source a suitable replacement and be able to solder it on to the board
Был ли этот ответ полезен?
Оценка 2
2 Комментариев:
you are wrong
из
@spocksbrain how exactly, does the posted photos not show a broken button ( yes ) is a button replaceable ( yes ).
из
iFixit does have the part listed, but it's currently not on sale:
[связанный продукт отсутствует или отключен: IF260-022]
Currently I have this problem too (although the switch did not come off of the daughter board)
Оценка 0
2 Комментариев:
I ultimately decided to RMA the deck.
из
what does RMA mean?
из
the daughterboards still are not in stock and i suspect they sell out instantly whenever they are in stock. that fragile flimsy microswitch is the number 1 most broken piece on this hardware.
Оценка 0
Добавьте свой ответ
Taylor Spivey будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 8
За последние 30 дней: 57
За всё время: 2,180
