MacBook Air 13” wont charge
I was using my MacBook I got up to do something and when I came back the MacBook wouldn’t charge the screen is cracked and it won’t connect to my monitor without it being plugged in it never bad this problem before what do I do?
Это хороший вопрос?
Оценка 0
2 Comments:
First, there are quite a few different MacBook Air's so we really need to know which year. Locate your systems S/N and plug it into here to figure out what you have EveryMac - Lookup Then tell us ;-}
As to your problem a cracked screen can be the cause of your problems as things can short out. How about posting some pics so we can see the damage, if the lid or hinge areas is bent take a some pics of them as well Adding images to an existing question
Also when you plug in the MagSafe charger what color is the cords LED? Amber or Green
из
It’s a 2017 model the MagSafe led is green and there are no bends or dents in the lid or hinges
из
Добавить комментарий
