How to replace L button on my Nintendo switch. Parts and tools need?
Это хороший вопрос?
Это хороший вопрос?
When you say you want to replace the L button, are you talking about the plastic part you press, or the internal switch that makes the electrical connection between two wires?
If it's the former, there's a guide available on the French website SOSav that has a repair guide for that.
L button Left Joy-Con repair - Free guide - SOSav
The guide includes a list of parts and tools needed for the repair.
I didn't find a repair guide for the internal switch, but there is a video guide here on iFixit that purports to show you how to repair the L switch. Note that it involves resoldering what appears to be a loose connection between the switch and the circuit board.
How to repair L button Joy-Con - iFixit Repair Guide
There doesn't appear to be any guide available for replacing the switch itself, so it will take some research on your part to figure out how to take out the little circuit board it's mounted on and finding a suitable replacement.
Good luck with your repair; hope this helps.
EDIT: Actually, it appears you're in luck. Amazon has a replacement for the L button that includes the circuit board with the switch already mounted on it, so all you have to do is figure out how to remove it and replace it with the new switch assembly.
And, even better, someone called FixnotBuy has made a video showing how to replace the button assembly mentioned above.
How to fix the shoulder button (L-Button) on a Nintendo Switch Joycon - YouTube
Depending on exactly what the problem is, you should be covered now!
Был ли этот ответ полезен?
За последние 24часов: 0
За последние 7 дней: 8
За последние 30 дней: 39
За всё время: 1,423
