Repair guides, support, and troubleshooting information for the first 13-inch MacBook Air to feature Apple's ARM-based M1 SoC (with an 8-core CPU and up to an 8-core GPU). Released in November 2020 and identified by model numbers A2338 or EMC 3598.
I did a bad thing when trying to fix my track pad
Hi! I am determined to finish this repair myself! (Mostly because it suddenly dawned on me that I could have just bought a fancy external mousepad by now) Anyways, I have watched this video https://www.youtube.com/watch?v=ieZh6yww... a half dozen times (Bless Binh and his Ginea Pig) And of course when I got the parts I got all spitfire like I could just talk to computers like Binh and just went at it and foolishly pulled out the connection part that is mounted to the left just above the center screw with the old cable. Stoooooooooopid. What do I do? There are two broken pins. :( Do I get to add a soldering knife to my tool kit? I promise to be patient. I should have been patient and watched the video and followed along. Learning is expensive. Help me please? please. thank you!
Это хороший вопрос?
Счет 3
2 Комментариев
So I did buy a new track pad with the cable. It was when I was taking out the old cable I accidentally pulled that connection. So that connection is for that microphone? I’m totally cool without a microphone!
So I did the Install of the new parts minus that one connection but now the keyboard doesn’t work. It worked before the repair :/ gonna have to hook up a keyboard to see what is happening.
Thank you for your help!
из
@mmmara - so which answer solved the question? Accept the answer that fixed it
из
Добавить комментарий
2 Ответов
Наиболее полезный ответ
Hi
I can help you finish your repair!
If you can upload some photos of your broken connector will be able to give you some advice on how to fix it
Here’s a guide on how to add photos
Adding images to an existing question
If it is damaged you will most likely need to solder on a new one which I can help you along with over the answers forum
Hopefully this helps
Any questions please ask
Был ли этот ответ полезен?
Счет 2
5 Комментариев:
Hello! I updated my question with photos let me know if I can take better ones! Thank you so much for your answer!
из
@mmmara
Thanks!
Il have a look:-)
из
@mmmara
I have had a look and you will probably have to replace your trackpad
Or you could find one that isn’t fully working and desolder the connector from the other side of the board
But it’s entirely up to you
No matter what choice you make I am here if you need any help:-)
из
Hello, where i can get daughterboard for trackpad, keyboard and backlight keyboard, this part common problem if Macbook got watter damage.
из
@malta32
Is it the small board on the bottom of the track pad that you are talking about?
из
Well, you are quite lucky!
It's just the Microphone,
Alliterative:
If that's a huge problem you need to buy a new trackpad,
Part: MacBook Air 13" (A2337, Late 2020) Trackpad
Replace a trackpad compatible with an Late 2020 MacBook Air 13" laptop model A2337. Изображение
Товар
$65.99
Счет 1
Добавьте свой ответ
Mara буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 14
За всё время: 450
