power button and it turns green for a second before it turns red
Hi I'm having a problem with my ps3, I press the power button and it turns green for a second before it turns red again. Can you help me with this? Thanks
Update (08/17/2022)
https://youtu.be/4vVX12rwnp4
Это хороший вопрос?
Оценка 1
20 Комментариев:
Any other colors
из
Does it go green yellow red
из
Go green than red
из
I’m have video on that @cyberwolfew
из
Показать 15 больше комментариев
Добавить комментарий
1 ответ
@catlady209 usually the blinking red light means that the console has shut down because of overheating. It is possible that you have a clogged (air ducts) or bad fan. Check something like this video for a possible solution. For a further teardown and to check things out, use these guides PlayStation 3 Repair
Hope this helps to get your PS3 working again.
Был ли этот ответ полезен?
Оценка 0
3 Комментариев:
How to you know that?
из
Hi there @catlady209, iFixit Staff here to check in!
@oldturkey03 is one of our long time moderators, I'd trust him to fix just about anything. Follow his advice and check back in. If this doesn't do it, we can help you figure out something different to try.
из
Добавьте свой ответ
Princess kk Barton будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 2
За всё время: 149
