Dell Latitude 6520 displays shutting down
Why do my Dell Latitude 6520 displays shutting down despite not being in shutting down or sleeping mode?
Это хороший вопрос?
Это хороший вопрос?
Hi,
Just verifying that the lid switch setting is set to do nothing?
If not alter it and then check if the problem still occurs.
If it doesn't then there may be a problem with the lid switch (or sensor) thinking that the lid is closed when it isn't.
Just trying to eliminate things.
Был ли этот ответ полезен?
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 27
2 Комментариев
Hi,
Is the laptop turning off or is it that the display is just turning off i.e. fan still operating, lights on etc?
Does it do this with the charger connected?
из jayeff
The laptop turns off like the system is going into hibernation. Nothing is on anymore after going off I have to turn it on back. Although it will resume back to where I was after turning it on. And this happens whether on battery or changing.
из Emeraldsbest
