The 5th generation BMW 3 Series is based on the E9X platform. The car pictured is a E90 chassis. The E9X chassis was used from 2004-2013 when the F1X chassis was released. When talking about a non-specific chassis, this generation is typically referred to as the E9X chassis since there are multiple chassis for this generation of 3 series, depending on the body style (E90/E91/E92/E93).
28вопросов Показать все
My car overheats and one of the hoses behind the radio deck blows air?
In my 2008 bmw 335xi My car overheats and one of the hoses behind the radio deck blows air?
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Выбранное решение
When did you clean your radiator and coolant system? I think your radiator has been choked. A radiator is made up of small pipes that flow the coolant liquid. This coolant gets heat while moving in the engine. The engine becomes cool and the coolant got heat.
With the help of a radiator pump, it reaches the radiator and gets cool by a fan and air. Now cooled coolant once again went to the engine and gets heat from the engine. This process keeps running while your vehicle starts.
If the radiator pipe gets choked, the coolant won't flow in it and cool. You have to clean the radiator from time to time. Look at the chocked radiator pic below:
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Adrian ramon будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 2
За всё время: 49
