New battery fitted .. charges and visible but won't operate on battery
Hi
Microsoft surface 2 Laptop battery replaced successfully. It is recognised and charges to 100% but as soon as I disconnect the power supply it shuts down. Have tried software fixes but I belive it is hardware.
Это хороший вопрос?
3 Комментариев
Hi there
I replaced with the same make from Microsoft (https://www.laptop-battery.org.uk/laptop...) and with the right connector.
I checked both batteriers with a DC voltage meter and the original was 7.5v but the new one was 8.5v. Should that make a difference ?
Thanks
из Craig Smyth
Craig Smyth always double check your work to make sure nothing got missed. Check the connector and check the pins. Make sure there is no damage.
из oldturkey03
Hi there
Thanks for the answer. I checked and double checked it. I was very careful and there was no damage and the pins were fine.
из Craig Smyth
