MBP doesn't power on; Power Pads location on MacBook Pro 17" A1229?
This MBP 17" Mid-2007 doesn't power on at all - no signs of life. Battery is good/fully charged. I've tried:
- swapping memory for known good memory
- removing internal HD (and internal HD cable) and booting from external drive
- resetting SMC
- using different power adapter, and booting from only battery or only power adapter.
Power cable light is green, and power flows through to an external drive connected via Firewire.
Internal drive is known good (tested in another Macbook).
The only advance problem I had prior to it not powering on at all: the previous night I'd put it to sleep by closing it, connected to power. The next morning it had shut itself down.
I'm down to likely either a bad logic board, or bad keyboard or keyboard cable.
In order to rule out problems with the keyboard or other devices, I'd like to power on using the power pads on the logic board. But, I can't find them on this model.
Where are the power pads on this model Macbook Pro?
Also, any other suggestions for troubleshooting?
Это хороший вопрос?
3 Комментариев
Anyone? The main thing I'm looking for is the location of the power-on pads on the logic board.
Anyone have the service manual for this model, and willing to look it up?
(for those who aren't familiar with these, all (most/some?) Macbooks have a pair of pads on the logic board, which when shorted out with a pair of tweezers, powers on the computer, without the keyboard or other power switch attached.
из Phillip Garrison
OK - I finally found the pads myself, after about 45 minutes of staring at the board.
The pads on this model are about 1" above the right side of the battery compartment, and 1.5" right of the memory. Labeled "PWR ON".
Unfortunately, still no life. So, looks like probably a bad logic board.
из Phillip Garrison
I know it an oldy now... gonna try a reflow, it's still a very nice machine for video even though I have a retina now thanks for the info, I was staring like a muppet as well
из feeds
