Wide Vertical Bar Down The Display - Have you seen this before?
About a month ago about a 2" wide grey semi-transparent vertical bar appeared on the display. After changing the background color to blue, I noticed it has ghosting.
Before I tear into it, I wanted to ask the community if you have seen this before?
I'm guessing it's either the flex cable, or the display itself. A $15 flex cable is easy enough to replace. However, if you've seen this same issue and it was the display, I'll probably just sell it as-is on ebay and go ahead (it's about that time) and move up to a M1 or M2 (will probably go with a mini this time around).
Thanks.
I took screenshots of the display, and the line doesn't appear in the images. So, are photos that I took with my phone.
Photo (below) zoomed and cropped to show the ghosting letters; The vertical bar is the same size as the one shown above.
Это хороший вопрос?
I would double check things here by connecting an external display via the Thunderbolt port connection. Is that screen showing a clean image?
из Dan
@danj
Yes, the external display is fine. Also did an SMC and PRAM reset. In addition, I booted Linux Mint and the built in display still shows the vertical bar. So, it's not a driver issue -- either that flex cable or the display itself.
из Country Computer Service
