Model Number A1707. Released June 2017, this MacBook Pro features Kaby Lake processors up to the 2.8 GHz quad-core Intel Core i7 processor with Turbo Boost up to 3.8 GHz.
284вопросов Показать все
Replaced battery, now left side fan is running at 7,000rpm constant.
Hello forums folk,
I've seen this issue somewhat addressed on here a few times. If I had seen a fix I would not be writing this!
So a few days ago I performed a battery replacement - I followed the guide on this site to a T, and took my sweet time. Upon start up I noticed the left side fan whir to a pretty aggressive start. I have reset the SMC, and NVRAM numerous times to no avail. I just received a replacement fan (from ifixit as well) and just installed it only to have the same issue. My mac fan speed at shows roughly 7,000rpms at all times on the left fan and it will not take to any custom speed input.
At a loss here guys and gals, initially did this to save time and money - can't really afford to give my only computer to Apple for 2-3 weeks, but now here I am and its seeming like I don't have much of a choice.
Any thoughts, tips, tricks, are more than welcome - thank you!
EDIT* diagnostic check shows
"there may be an issue with the fan. Reference Code: PPF004. Additional reference code PPF003"
Это хороший вопрос?
Оценка 1
Добавить комментарий
2 Ответов
Hey Dillon!
Sorry you got this problem, doesn't seem fun at all to hear all day. Do you happen to know if by any chance you accidentally touched or messed around with any setting or anything on board? (like a fan controller)
Был ли этот ответ полезен?
Оценка 0
1 Комментарий:
hey!
thanks for your response, I did not (knowingly) touch or mess around with any setting or anything on board. simply removed the logic board, removed the old battery, and reassembled.
из
I'm suspecting you might have not fully seated the ribbon cable, connector latch not closed or damaged the connector or load resistor
Оценка 0
2 Комментариев:
this is for the fan correct?
I'm not sure how that would have happened when I only replaced the battery to begin with, which is what initially brought this issue to light. this issue did not exist before changing the battery, and still exists now after replacing the fan. the fans ribbon cable was not touched when I replaced the battery. at least not knowingly.
do you recommend opening back up to view if the load resistor is missing?
из
@dukegonzo - Yes this is the fans connection to the logic board as the keyboard cable carries the signal to the logic board (Apples efforts to reduce the parts count)
I see no way to solve your issue without at least inspecting things. Take a picture so we can see things too posting it here Adding images to an existing question
из
Добавьте свой ответ
Dillon Smith будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 37
