The Samsung Galaxy A53 5G Is a Mid-Tier phone released by Samsung on March 17, 2021
13вопросов Показать все
Can't receive text messages
Does anyone know how to solve the issue of not being able to receive text messages unless you turn your phone off and then back on and then I get flooded with text messages from the day before
Это хороший вопрос?
Оценка 0
1 Комментарий
I get text messages, says they are received, yet don't show up on the screen for up to an hour after showing they were received. Phone us also A53 5G
из
Добавить комментарий
2 Ответов
Выбранное решение
Please try the following:
  1. Reset your phone's network settings. Open the settings app and type "Reset network settings" in the search box. Follow the prompts to erase the settings. Afterward, you will need to re-enter your WiFi password and re-pair any Bluetooth devices.
  2. Uninstall/reinstall your text message app, or use Google's Message app at https://play.google.com/store/apps/detai...
Был ли этот ответ полезен?
Оценка 1
4 Комментариев:
That didn't work.
Don't know what else to do. It all started after the software update took place
из
@Daniel Marzahl If it started after an update, perform a factory data reset on your phone. This reset option is in the Settings app, as well. If nothing works, please call your cellular carrier.
из
I'm having the same issue after the August 1 update for the A53 on Tracfone (Straight Talk/Verizon). I'm using the Google Messages app and had disabled Chat Features. Re-enabling Chat Features seems to have helped, at least for the past 8 hours. Did you end up doing a factory reset, and did it help?
из
I am also having this issue
из
I'm also having this issue
Оценка 0
3 Комментариев:
I'm also having this issue, I've sent the OTP to another mobile device and the code came through within seconds, but when I requested OTP code to be sent to my Samsung phone, no code was sent!
из
I’m having same issue on my Samsung Galaxy A53 5G, not getting text from my contacts. I can send out but not receive, at leading not with contacts. I get text from doctors office and FedEx etc but not my contacts. So frustrating. I have tried everything!
из
I have the same issue - can't receive ìmessages - can send but can't receive, very frustrating
из
Добавьте свой ответ
Daniel Marzahl будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 6
За последние 7 дней: 27
За последние 30 дней: 110
За всё время: 4,965
