The Galaxy A12 is a low-end slate Android smartphone released by Samsung in November 2020 as a successor to the Samsung Galaxy A11. Identifiable by model number SM-A125 (followed by version/carrier-specific character.
154вопросов Показать все
I dropped my phone in water and now certain apps don't function prope
I dropped my phone in some water. It turns on and allows me to open some apps but not all apps. What do I do or where can I get it checked out?
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
@benstey could very well be that you are having issues with your memory IC's. You did not tell us what you did about the water damage. I suggest you deal with that first.
For now you want to stop continuing to try to charge, sync or otherwise use your phone. This potentially can make a bad situation worse. This may further damage your phone.
The next thing to do is to clean it. Disassemble your phone using something like thios video You must remove all EMI shields. If you do not remove those, you might as well not do anything. After you removed those, clean the whole board, connectors and all with +90% isopropyl alcohol. Follow this guide , and even so it was written for an Apple 3G iPhone, all the points are still pertinent to your phone. While you clean your board, check for any obvious damage, like burned or missing components etc. When it is properly cleaned, replace the battery. All these steps are to avoid delayed failure caused by corrosion. Best thing to do would be to clean it with an ultrasonic cleaner, but if you do not have access to one, this will at least help. Once all this is done, reassemble your phone and reevaluate. Until it is cleaned, everything will only be a guess. Even with all this, water damage has only a small chance to be fully repaired, but at least you can give it a try.
It might help if you post some good pictures of your circuit board with your QUESTION. You must edit your QUESTION to insert the images. Use this guide Adding images to an existing question for that
iPhone Изображение
Инструкция
Repairing iPhone Liquid Damage
Сложность:
Сложно
1 - 2 hours
iFixit Изображение
Инструкция
Сложность:
Очень просто
2 - 5 minutes
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
Stey будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 4
За всё время: 54
