Motorola's Moto G Power 2021 edition was released on January 14. It features a 6.6" Max Vision HD+ (IPS) display, 48 megapixel triple camera system, and expandable microSD storage.
12вопросов Показать все
Charging cord doesn't connect
When I plug it in to charge or connect to my car, the connection is very hard to get connected, I have to mess with it and set it just right or it won't connect. What can I do?
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
Наиболее полезный ответ
either fluff or something in the port or its possibly damaged
Был ли этот ответ полезен?
Оценка 1
@treefarm if you find that the connector is actually damaged, you can replace the USB board (daughterboard). Something like this will work. Of course, check the connector coming from your charger first. Something like this video shows you how to get there. Careful on this model. The battery is glued in and a royal PITA to remove.
Оценка 0
Добавьте свой ответ
Robert Hoover будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 2
За всё время: 149
