2013 chevy cruze, my front window on driver side won't roll up or down
I have a 2013 chevy cruze, my front window on driver side won't roll up or down
Это хороший вопрос?
Это хороший вопрос?
M A check the switch or the motor. See if you have power on it. I attached the GM diagnostics for this power window.Power Window Diagnostic It's really overboard and goes into a lot of depth. Also, check the part of the SM that shows the repair of the switch and the motor.Power Window Repair Of course you also want to check the wiring.
Был ли этот ответ полезен?
За последние 24часов: 2
За последние 7 дней: 15
За последние 30 дней: 88
За всё время: 2,524
If no one here is an expert on Chevy Cruze troubleshooting, your best alternative as a diyer before resorting to dealer or repair shop $ervice$ would be searching for Chevy Cruze forums for owners more likely experienced and helpful with specific info. Basically this problem breaks down to; fuse, window switch, wiring, power window unit and window mechanicals.
из F Dryer
