Released in November 2020, the 13" MacBook Air features Apple's Arm-based M1 SoC with an 8-core CPU and up to an 8-core GPU. (Model A2337 / EMC 3598 with two Thunderbolt 3 ports)
81вопросов Показать все
My backlight is very dim
Bassicly i was sitting down for a cup of tea with my Mac and I spilt it onto my keyboard. I have got it all out pretty much and everything works but, the keyboard backlight is very dim even at max keyboard brightness.
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
You have damaged the keyboard backlight unit which is likely not worth repairing given the cost of the part and amount of work needed. MacBook Air 13" (A2337, Late 2020) Upper Case with Keyboard you’ll need to strip down the system to swap out the assembly. Even if you try to patch the backlight plate it’s requires even more work.
MacBook Air 13" (A2337, Late 2020) Upper Case with Keyboard Изображение
Продукт
$299.99
Был ли этот ответ полезен?
Оценка 4
2 Comments:
Is it worth taking it to a repair shop as it’s annoys me?
из
They will likely say the same. Replacing the assembly is what I would do. But consider the costs. The backlight part is not available independently.
из
Добавьте свой ответ
Cole будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 23
