Wi-Fi only version of Apple's 2nd generation iPad Air. Model A1566.
212вопросов Показать все
My Wifi is Greyed out, How could I fix it?
I have tried a reset and done everything WiFi works over Bluetooth using my iPhone but is very slow, It used to work just fine but now it doesnt it is a 16GB iPad Air 2.
Это хороший вопрос?
Оценка 2
1 Комментарий
Why hello Xavier. Trying to fix your iPad lol The wifi antenna might be bad.
из
Добавить комментарий
2 Ответов
Наиболее полезный ответ
This will not be an antenna issue. If the Wi-Fi is greyed out you defiantly have a board issue. You will need to check that the Wi-Fi chip is getting power, if it is you will need to re-ball or replace the chip. If it isn’t getting power you will need to find the faulty component that has failed. Microsoldering will be needed to fix this problem.
Был ли этот ответ полезен?
Оценка 4
1 Комментарий:
UPDATE: I just plugged it in and powered it on for the first time in a month, Wifi is back so I think it keeps getting overvolted or something like that.
из
It sounds like it could be an issue with the Wi-Fi Antenna. If you follow this guide to check the state of the antenna. I would attempt to reseat the antenna before attempting a replacement. Otherwise, it sounds like it could be an issue with the logic board.
Оценка 2
1 Комментарий:
из
Добавьте свой ответ
Xavier K будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 12
За последние 30 дней: 76
За всё время: 994
