The April 2014 update of Apple's 13" MacBook Air features refreshed dual-core i5 and i7 processors, plus slightly increased battery performance.
303вопросов Показать все
trackpad doesn't work properly after installing new top and keyboard
Have a MBA 13" 2014. Keyboard was bad, so bought a new top with the keyboard, exchanged everything into the new case and used the same trackpad and cable from the operating unit (same motherboard, etc. ) now the trackpad doesn't work correctly (no click select, scroll ok. Cable is connected correctly, it is the same trackpad and cable and motherboard... Issue? tried reseating both ends of the cable, no difference. Any ideas? Di all the usual stuff SMC, NVRAM, etc.
Это хороший вопрос?
Оценка 1
Добавить комментарий
1 ответ
Выбранное решение
Hi
Hopefully this issue isn’t a board level issue or a cable/track pad issue
When things like this randomly stop working properly I find cleaning the connectors(both board and cable) with some isopropyl alcohol
I would also pay close attention to any “dull”looking pins and if any are sound throughly clean them
Hopefully this helps
Any questions please ask
Был ли этот ответ полезен?
Оценка 2
7 Комментариев:
Thanks, Yes, I did that and got a different operational result, so ordered a new cable. Looked under scope and the one (that was part of the system was looking OK0 The user then told me her trackpad had not been operating properly for sometime. Hmm. So have a replacement on order. Always ask all the questions first to see if there is something else going on... HA. The new top & keyboard (original repair) operate fine., Thank you.
из
@macman67
Your most welcome
Please let me know if there is anything else
из
Tried cleaning, then ordered a new cable from Beetstech.in Chico, CA Alls well, Thanks.
из
@macman67
That’s great!
Did you install the new one or are you still waiting to receive the part?
из
Got the parts the next day and installed, works like new.
из
Показать 2 больше комментариев
Добавьте свой ответ
Carl Schultz будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 8
За последние 30 дней: 9
За всё время: 40
