Узнайте о навыках, которые могут понадобиться вам для ремонта вашего устройства.
What product do you recommend for removing a smartphone battery?
What product do you recommend for removing a smartphone battery sticker? I wanted to get iFixit Adhesive Remover but I saw that it is no longer available. Last time I did it through a hair dryer, but I still risked ruining the battery a bit.
Это хороший вопрос?
Счет 3
Добавить комментарий
2 Ответов
Выбранное решение
Hi
See my answer as a extension of the amazing answer @guardian10 has kindly provided
IFixit’s adhesive remover is good but iFixits iOpener is also a great choice
A hair dryer works great too along side isopropyl alcohol
Also here’s a little tip:when prying battery’s up try your best to AVOID metal tools as they can puncture the battery if you aren’t careful
Plastic tools don’t have as high a chance of puncturing a battery but the risk is still there so it’s best to stick to the ones that are flat and don’t have any sharp edges
Hopefully this helps
Any questions please ask
Был ли этот ответ полезен?
Счет 6
4 Комментариев:
Thank you very much for your advice. Everything went well, however, now I have encountered new problems.
https://it.ifixit.com/Risposte/Visualizz...
Do you have any advice?
из
@most99
Can you see any damage to the connector or cable
Also did you unplug it
из
which one in particular?
из
@most99
Sorry I should have said in the previous comment
I am wondering about the camera
из
While it is preferable to use Ifixit adhesive remover, you can use regular isopropyl alcohol to weaken the adhesive, then pry the battery up.
Счет 5
1 Комментарий:
из
Добавьте свой ответ
Gavino Santu буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 5
За последние 30 дней: 37
За все время: 898
