Well When I Put My Dyson To Charge It Doesn't Charge
I Think It Is Not Normal
Это хороший вопрос?
Это хороший вопрос?
@sebastianputura check the charger itself first. Make sure it is plugged in etc. Then check the connection between the Dyson and the charger. Make sure they connect properly and nothing is obstructing the charging port. After that, you may have to try a new battery.
Был ли этот ответ полезен?
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 4
За всё время: 61
4 Комментариев
Hi
Do you get a light in the charger?
Also have you tried a different battery?
из HelloMacOS
No I Don't get a light in the charger
из Sebastian
No I haven't tried a different battery
из Sebastian
@sebastianputura
Do you have a different battery or charger to try?
из HelloMacOS
