Hi Elizabeth,
There are a lot of very smart people on this site who know a lot about MacBooks, so hopefully you'll get some authoritative answers, but in the meantime if that was my computer, here's what I'd try.
First off, it doesn't sound like the battery is working right, does it? I'd be really curious if it behaves the same with the battery unplugged; obviously you'll have to have the power cord connected. If it does, I'd say the replacement battery is defective; iFixit seems to have a pretty good one year warranty on batteries, so they should be able to help.
If that doesn't help, the next thing I'd try would be to put the old battery back in and see if it goes back to working the way it used to. Again, if that works then the new battery has problems and you should be able to get it replaced.
If neither of those suggestions helps, get yourself a magnifying glass and a bright light and look carefully at the battery connectors; both those on the cable and the one on the motherboard. Look for any dirt or dust in the connector and check for any bent or missing pins. If you find anything bent you might be able to straighten it with fine tip tweezers. Also, clean both of them with 90% or higher isopropyl alcohol (not the 70% stuff we all have around the house), reassemble and see if anything changes.
Assuming you followed the iFixit guide, you shouldn't have had to unplug anything else in order to replace the battery, but while you're in there it wouldn't hurt to check any connectors near the battery in case they got bumped in the process of swapping batteries.
That's all I got for ya at the moment. Let us know if any of those ideas help; if not, we'll see what else we can do to help you figure out what's going on with your MacBook.
Был ли этот ответ полезен?
Проголосовали
Отменить
Счет
Отмена
Прокрутите эту тему, чтобы найти подходящее место для этого комментария. Затем нажмите "Прикрепить комментарий к этому сообщению", чтобы переместить его.
2 Комментариев
With the MagSafe charger plugged in what is it’s color? Amber, Green or not lit.
Is it able to boot with the charger plugged in? If it is download this gem of an app so you can see what’s happening CoconutBattery take a snapshot of the apps main window with the battery tab opened up an post it here so we can see it too.
из DanJ
@danj Unfortunately with this laptop not even turning on, downloading an app is not an option.. the charger plugged in has been amber color
из Elizabeth Lee
