Дата выхода 25 сентября 2015 г. Модель A1687 / A1634. Ремонт данного устройства схож с предыдущими моделями, требующий отвертки и инструменты для вскрытия. Доступен в версиях GSM или CDMA; с 16, 64 или 128 ГБ памяти; в цветах: Серебристый, Золотой, «Серый космос» и «Розовое золото».
Why is my screen not responding to touch?
I have been trying to fix my iPhone (6 s plus) with no avail. When I press a button the screen displays things, but the screen doesn’t respond to touch input. Restarting the phone doesn’t work either nor does replacing the screen. I also didn’t have Siri on so I can’t unlock the phone to connect to iTunes. The screen stopped working when I changed the battery and because the initial battery was applied with glue, I used to much alcohol trying to remove the glue. I only want the data on the phone. Is there a solution?
Это хороший вопрос?
Оценка 0
Добавить комментарий
Ответов (1)
Наиболее полезный ответ
Hi akwardllama1234,
Unfortunately, you need to (at the very least) open your phone up again. Disconnect the battery first, then disconnect the screen. Clean the connectors with >99% isopropyl alcohol before reconnecting in reverse order. Test to see if touch functionality is restored before closing up the phone.
If the clean and reseat doesn’t fix it, you’re looking at a screen swap, to be able to get touch working so you can recover the data. There is no way to get the phone connected to a computer and authorizes for backup, without touch functionality.
The 6 / 6 Plus phones had something called “touch disease”. This was because the touch IC on the logic board failed. Not applicable to 6S and above, because the IC is no longer into logic board.
Был ли этот ответ полезен?
Оценка 2
Добавьте свой ответ
akwardllama1234 будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 51
