A gaming PC is a personal computer specifically designed and optimized for playing video games.
32вопросов Показать все
Monitor is saying no signal but pc is running . Been like this since i
So i bought a ABS Gladiator from newegg and every since i received it the monitor has been saying no signal. I’ve tried every method i can think of and researched about and nothing seems to work. So I turned to my community to seek a expert for assistance. I’ve uploaded the following pictures to show if anything is wrong. The specs for my pc is:
  • CPU: Intel Core i7-12700KF 3.6GHz (5.0GHz Turbo) 12-Core 20-Thread
  • GPU: NVIDIA GeForce RTX 3070 Ti 8GB (Brand May Vary)
  • Chipset: Intel Z690
  • RAM: 16GB (2x8GB) DDR4 3000MHz
  • SSD: 1TB M.2 NVMe SSD
  • CPU Cooler: RGB AIO Cooler
  • PSU: 700W Gold
  • Case: Deepcool Matrexx 50
  • Operating System: Windows 10 Home
Это хороший вопрос?
Оценка 0
3 Комментариев
@jayeff the mother board is a Asus Prime z690-p wifi ddr4
из
@jayeff There isn’f a audio speaker on the motherboard.
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
@jose170568
Can you get into BIOS with a display?
Do you hear 1 beep after it starts up?
If no beeps heard at all check if there is a system speaker (example only) attached to the motherboard (see System warning speaker header pin location p.1-19 of the user manual)
It may not be passing POST (power on self test) for some reason - see p.2-21 of the manual for beep codes meaning
Был ли этот ответ полезен?
Оценка 2
14 Комментариев:
@jayeff I cannot get into BIOS with display. I hear no beeps . The version of z690-p is ASUS Prime.
из
@jayeff As you can tell I’m sort of new to pc configuration
из
@jose170568
I was updating my answer above with what to check for to get beeps, when you replied so follow that.
из
@jose170568
Did you install the ram modules in slot A2 and B2 - see p.1-5 of the manual? (not A1 & A2 or B1 & B2)
Make sure that the power cord is discnnected from the PSU when removing /installing anything on the motherboard
из
@jayeff I have ram stick installed in A1 & B2, Also power supply disconnected
из
Показать 9 больше комментариев
Добавьте свой ответ
Jose Perez-Garcia Jr будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 6
За всё время: 727
