PowerA's Gamecube Style Wireless Controller is a third party controller made for the Nintendo Switch. The controller is modelled after the beloved Gamecube controller, offering a wireless alternative to Nintendo's own controllers.
3вопросов Показать все
How do I fix upward drift in the left joystick?
The left joystick will randomly drift up, sometimes a lot and sometimes a little, but nevertheless it is really annoying when I'm playing Smash Ultimate and I try to do my neutral B attack but instead it does the up B due to the drifting. How can I fix this issue? (Also this is a wired controller, I could only find the wireless one on here.)
Это хороший вопрос?
Оценка 1
Добавить комментарий
1 ответ
Hello, generally the main fix for stick drift is replacing the whole stick module, however you may want try cleaning by rubbing ips on the stick while moving it, if that didn’t fix it go forward with a disassembly and cleaning, or stick module replacement.
Happy fixing
Был ли этот ответ полезен?
Оценка 0
1 Комментарий:
Do you have a link for a replacement stick module?
из
Добавьте свой ответ
ZynikaEDM будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 12
За последние 30 дней: 101
За всё время: 1,520
