Выпущено 21 сентября 2018 г. Модели A1921, A2101, A2102, A2104. Доступен как GSM, CDMA / eSIM или nano-SIM / 64, 256 или 512 ГБ / серебристый, золотой или космический серый. (Произносится как «iPhone 10 S Max.»)
375вопросов Показать все
userspace watchdog timeout 180 sec
Probably phone got a bit of water through the scratches in the screen, and i've got userspace watchdog timeout problem the log files is saying something like that
{"bug_type":"210","timestamp":"2022-12-06 13:25:03.48 +0300","os_version":"iPhone OS 13.3 (17C54)","incident_id":"2CADE8A7-61C4-4F43-B8D4-BAA1BD14762F"}
"build" : "iPhone OS 13.3 (17C54)",
"product" : "iPhone11,6",
"kernel" : "Darwin Kernel Version 19.2.0: Mon Nov 4 17:46:11 PST 2019; root:xnu-6153.60.66~39\/RELEASE_ARM64_T8020",
"incident" : "2CADE8A7-61C4-4F43-B8D4-BAA1BD14762F",
"crashReporterKey" : "f3212b3e602ab2d373db1407d020ca8d52d6e226",
"date" : "2022-12-06 13:24:54.94 +0300",
"panicString" : "panic(cpu 3 caller 0xfffffff016b99bf8): userspace watchdog timeout: no successful checkins from com.apple.thermalmonitord since wake\nservice returned not alive with context : is_alive_func returned unhealthy : current ffc6ffffffffffff, mask 33ffffffffdff, expected 33ffffffffdff\nservice: com.apple.backboardd, total successful checkins since wake (180 seconds ago): 19, last successful checkin: 0 seconds
was trying to connect another charging port but nothing changed :(
Это хороший вопрос?
Оценка 3
3 Комментариев
Thank you! i'll try out to find OEM part
из
o meu aparelho apresenta o seguinte erro
"panic(cpu 0 caller 0xfffffff01665d564): userspace watchdog timeout: no successful checkins from thermalmonitord (2 induced crashes) in 205 seconds\nservice returned not alive with context : is_alive_func returned unhealthy : current 6ffffffffffff, mask 37ffffffffdff, expected 37ffffffffdff. SD: 0 BC: 0 RC: 0 BS: 1, Missing sensor(s): Prs0 \nservice: backboardd, total successful checkins in 903 seconds: 86, last successful checkin: 0 seconds ago\nservice: SpringBoard, total successful checkins in 876 seconds: 85, last successful checkin: 0 seconds ago\nservice: mediaserverd, total successful checkins in 903 seconds: 87, last successful checkin: 0 seconds ago\nservice: audiomxd, total successful checkins in 903 seconds: 87, last successful checkin: 0 seconds ago\nservice: logd, total successful checkins in 903 seconds: 87, last successful checkin: 0 seconds ago\nservice: thermalmonitord (2 induced crashes), total successful checkins in
qual seria o erro apresentado
из
@digitalemporium Prs0 is the pressure sensor associated with the barometric pressure port at the bottom of the phone. It's mounted on the lightning port flex cable assembly, so that's the part you'll need to replace to fix the problem.
из
Добавить комментарий
6 Ответов
Наиболее полезный ответ
As was already mentioned, the panic you linked generally points to some thermal sensors that are failing to check in. But not always. If there are other panics, they may give us more data to go off of. Just like any other sort of mystery, or science experiment, more data is generally better. You can use paste bin to post the full panics and link them back here so we can get a look at them without it cluttering up the original post.
Also, if you have not done a software update yet, or restore (via recovery mode is best since it will be less likely to restart in the middle) I would give that a go.
You mention in your question that there may have been water that got in through scratches in the screen. Scratches? Or actual cracks? I will also mention that despite the water resistant rating of the phone, this resistance degrades over time so even if the screen was intact, it’s possible liquid got into the phone. If there is a chance that was the case, first thing I would do is look for any signs of liquids inside. Finding out where or if there was any liquid damage is going to give you the best clues.
Also, when you’re testing, are you fully reassembling the phone? Connecting just certain components? The XS Max needs both a good power button cable and a good charge port assembly to avoid this problem.
Был ли этот ответ полезен?
Оценка 3
4 Комментариев:
please help me, my phone keeps on restarting every 30mins - 1hr and the panic log shows.
"panicString": "panic (cpu 1 caller Oxfffffff0151ed138): userspace watchdog timeout:no successful checkins from SpringBoard in 180 seconds\SpringBoard has not exited since first loaded nservice: backboardd. total successful checkins in 3357 seconds:333, last successful checkin: 0 seconds ago\service: SpringBoard, total successful checkins in 3330 seconds: 313, last successful checkin: 180 seconds ago\nservice: mediaserverd, total successful checkins in 3357 seconds: 317, last successful checkin: 150 seconds ago\nservice: loqd, total successful checkins in 3357 seconds:
315, last successful checkin: 180 seconds ago\service: thermalmonitord, total successful checkins in 3357 seconds: 317, last successful checkin: 130 seconds ago\nservice: runningboardd, total successful checkins in 3357 seconds: 315, last successful checkin: 180 seconds ago|nservice: wifid, total successful checkins in 3357 seconds: 318,
из
@gyle soliza This panic has been showing up rather often recently with some of the early builds of iOS 16. The solution in my experience has been to reset the phone to factory settings. I would also try and update to iOS 16.2 if you haven't already. I haven't heard any reports as to whether to resolves the issue. But it's very likely software related.
из
@gyle soliza hey does restoring the phone helps?
из
please help me, my phone(iphone 11) keeps on restarting
panic(cpu 3 caller 0xfffffff025c31c08): userspace watchdog timeout: no successful checkins from wifid in 180 seconds
wifid has not exited since first loaded
service: backboardd, total successful checkins in 1826 seconds: 182, last successful checkin: 0 seconds ago
service: SpringBoard, total successful checkins in 1800 seconds: 180, last successful checkin: 0 seconds ago
service: mediaserverd, total successful checkins in 1826 seconds: 181, last successful checkin: 0 seconds ago
service: logd, total successful checkins in 1826 seconds: 182, last successful checkin: 0 seconds ago
service: thermalmonitord, total successful checkins in 1826 seconds: 181, last successful checkin: 0 seconds ago
service: runningboardd, total successful checkins in 1826 seconds: 182, last successful checkin: 0 seconds ago
service: wifid, total successful checkins in 1826 seconds: 164, last successful checkin: 180 seconds ago
service: configd, total successful checkins in 1826
из
I dunno, guys; thermalmonitord is a 'daemon'; i.e., a task that runs in the background and, as the name implies, it's job is to keep an eye on the thermal sensors. However, in most cases where the direct communication with the sensor has failed, it will tell you which sensor it was that it can't talk to.
In this case, though, what I'm seeing is that trying to talk to the thermal monitor daemon failed; the call to ask it for information returned a status of "not alive" after it failed it's periodic check in. So in this case it's the software that checks the sensors that has failed, rather than one of the sensors it's supposed to be checking.
That is specifically a software problem, not a hardware one, so replacing hardware won't fix that problem except indirectly. The things is, we don't know why thermalmonitord crashed; it could be corrupted firmware, bad NAND memory, or some other hardware factor we don't know about.
So whenever you have something you know to be a software error such as this, the first thing to do is to do a restore or update of the operating system in order to replace any corrupted storage with a good copy. After that, you check the phone and see if it's working again; if not, then you have to start looking at hardware issues.
@flannelist Alisha, you're obviously experienced in iOS/Linux internals; what do you think?
Оценка 2
2 Комментариев:
@dadibrokeit, I think (reading back my answer) that I worded myself wrong. Thermalmonitord is indeed a daemon (like just about anything that ends with a d), and it’s job is monitoring sensors.
I made the assumption that something was left out of the posted panic, as there are a few sections on the thermalmonitord I’d expect to see, that I don’t. Like SD, BC, RC, etc. and the specific sensor, like PRS0, MIC2, ++
из
@geirandersen I had to actually pull up a panic to check the exact order of the verbiage, because I might also have made a similar determination at least with regards to the necessary data being omitted from the snippet of the panic that’s present.
I think a software update in this case (or restore if data isn’t necessary) via iTunes would be a reasonable start. Otherwise, I would want to see if other panics read the same way. I’m gonna throw my own answer in the ring so I can get all the data I want in there, but I think both of these thoughts are sound. But I think we’re still missing a crucial bit of data.
из
@jakebravo Your Phone is saying it’s not getting any data back from thermalmonitord, which is a sensor on the charge port / flex assembly.
Did you try swapping to a replacement (3rd party) assembly? It was a little unclear in question. I know some of the 3rd party ones come without the sensors, which is why it can cause issues with replacement parts.
Оценка 1
6 Комментариев:
i've just connect new flex cable, not install it to the phone
из
@jakebravo I’d start by downloading and running this tool iDevice Panic Log Analyzer. This could maybe tell you a bit more.
The new flex, did you buy it from a reputable seller or a cheap one from any seller?
из
@jakebravo 99.999% that flex doesn’t have the sensors an OEM pull or high quality aftermarket one does, which is why you’re getting sensor errors :/
из
@jakebravo you need a genuine charge port replacement
из
Показать 1 больше комментариев
Guys please help,
{"bug_type":"210","timestamp":"2023-01-03 12:28:01.00 +0700","os_version":"iPhone OS 16.2 (20C65)","roots_installed":0,"incident_id":"7F3EBA60-B291-4701-8E9C-1507B21C37BF"}
"build" : "iPhone OS 16.2 (20C65)",
"product" : "iPhone11,8",
"socId" : "0x00008020",
"kernel" : "Darwin Kernel Version 22.2.0: Mon Nov 28 20:10:15 PST 2022; root:xnu-8792.62.2~1\/RELEASE_ARM64_T8020",
"incident" : "7F3EBA60-B291-4701-8E9C-1507B21C37BF",
"crashReporterKey" : "6af47c56c6da35c8301ff0a2d7ee9d8720802136",
"date" : "2023-01-03 12:28:01.88 +0700",
"panicString" : "panic(cpu 2 caller 0xfffffff0136abd38): userspace watchdog timeout: no successful checkins from logd in 180 seconds\nservice returned not alive with context : unresponsive dispatch queue(s): com.apple.firehose.io-wl \nlogd appears to not exist in launchd\nservice: backboardd, total successful checkins in 843 seconds: 82, last successful checkin: 0 seconds ago\nservice: SpringBoard, total successful checkins in 802 seconds: 65, last successful checkin: 150 seconds ago\nservice: mediaserverd, total successful checkins in 843 seconds: 65, last successful checkin: 160 seconds ago\nservice: logd, total successful checkins in 843 seconds: 64, last successful checkin: 180 seconds ago\nservice: thermalmonitord, total successful checkins in 843 seconds: 81, last successful checkin: 0 seconds ago\nservice: runningboardd, total successful checkins in 843 seconds: 76, last successful checkin: 0 seconds ago\nservice: wifid, total successful checkins in 843 seconds: 68, last successful checkin: 140 seconds ago\nservice: configd, total successful checkins in 843 seconds: 81, last successful checkin:\nDebugger message: panic\nMemory ID: 0xff\nOS release type: User\nOS version: 20C65\nKernel version: Darwin Kernel Version 22.2.0: Mon Nov 28 20:10:15 PST 2022; root:xnu-8792.62.2~1\/RELEASE_ARM64_T8020\nFileset Kernelcache UUID: 8631036BCCCF5DE9E3270CDB30F5633F\nKernel UUID: E162E369-A92E-3EB7-872F-862218FB860F\nBoot session UUID: 7F3EBA60-B291-4701-8E9C-1507B21C37BF\niBoot version: iBoot-8419.60.44\nsecure boot?: YES\nroots installed: 0\nPaniclog version: 14\nKernelCache slide: 0x000000000b0d8000\nKernelCache base: 0xfffffff0120dc000\nKernel slide: 0x000000000bcc0000\nKernel text base: 0xfffffff012cc4000\nKernel text exec slide: 0x000000000bd78000\nKernel text exec base: 0xfffffff012d7c000\nmach_absolute_time: 0x4b8046ecf\nEpoch Time: sec usec\n Boot : 0x63b3b90c 0x0002c5c5\n Sleep : 0x63b3ba1f 0x0002be32\n Wake : 0x63b3ba27 0x0006b16c\n Calendar: 0x63b3bcba 0x00081650\n\nZone info:\n Zone map: 0xffffffe0efcc0000 - 0xffffffe6efcc0000\n . VM : 0xffffffe0efcc0000 - 0xffffffe1d6324000\n . RO : 0xffffffe1d6324000 - 0xffffffe222ff0000\n . GEN0 : 0xffffffe222ff0000 - 0xffffffe309654000\n . GEN1 : 0xffffffe309654000 - 0xffffffe3efcb8000\n . GEN2 : 0xffffffe3efcb8000 - 0xffffffe4d6320000\n . GEN3 : 0xffffffe4d6320000 - 0xffffffe5bc988000\n . DATA : 0xffffffe5bc988000 - 0xffffffe6efcc0000\n Metadata: 0xffffffe00ebfc000 - 0xffffffe0103fc000\n Bitmaps : 0xffffffe0103fc000 - 0xffffffe0113f4000\n\nTPIDRx_ELy = {1: 0xffffffe4d6c26c08 0: 0x0000000000000002 0ro: 0x000000016ff770e0 }\nCORE 0: PC=0xfffffff012dfa9a8, LR=0xfffffff012dfa9a8, FP=0xffffffee79973f00\nCORE 1: PC=0xfffffff012dfa9a8, LR=0xfffffff012dfa9a8, FP=0xffffffee798b3f00\nCORE 2 is the one that panicked. Check the full backtrace for details.\nCORE 3: PC=0xfffffff012dfa9a8, LR=0xfffffff012dfa9a8, FP=0xffffffee796a3f00\nCORE 4: PC=0xfffffff012dfa9a8, LR=0xfffffff012dfa9a8, FP=0xffffffee796d3f00\nCORE 5: PC=0xfffffff012dfa9a8, LR=0xfffffff012dfa9a8, FP=0xffffffee79967f00\nCompressor Info: 42% of compressed pages limit (OK) and 16% of segments limit (OK) with 1 swapfiles and OK swap space\nTotal cpu_usage: 74102410\nThread task pri cpu_usage\n0xffffffe4d6c26c08 watchdogd 97 0\n0xffffffe4d66e9eb8 kernel_task 81 611313\n0xffffffe4d66c8418 kernel_task 0 5857151\n0xffffffe4d66c9810 kernel_task 0 5465907\n0xffffffe4d66c6978 kernel_task 0 3881542\n\nPanicked task 0xffffffe4d53fee78: 220 pages, 5 threads: pid 57: watchdogd\nPanicked thread: 0xffffffe4d6c26c08, backtrace: 0xffffffee7959f130, tid: 1502\n\t\t lr: 0xfffffff012dc6ba8 fp: 0xffffffee7959f170\n\t\t lr: 0xfffffff012dc697c fp: 0xffffffee7959f1e0\n\t\t lr: 0xfffffff012f0bdd4 fp: 0xffffffee7959f200\n\t\t lr: 0xfffffff012eff258 fp: 0xffffffee7959f270\n\t\t lr: 0xfffffff012efddf0 fp: 0xffffffee7959f300\n\t\t lr: 0xfffffff012d837b8 fp: 0xffffffee7959f310\n\t\t lr: 0xfffffff012dc6390 fp: 0xffffffee7959f6c0\n\t\t lr: 0xfffffff0134df108 fp: 0xffffffee7959f6e0\n\t\t lr: 0xfffffff0136abd38 fp: 0xffffffee7959f700\n\t\t lr: 0xfffffff0136ab5c0 fp: 0xffffffee7959f720\n\t\t lr: 0xfffffff0136aa474 fp: 0xffffffee7959f840\n\t\t lr: 0xfffffff013457cf0 fp: 0xffffffee7959f870\n\t\t lr: 0xfffffff013457fd8 fp: 0xffffffee7959fa00\n\t\t lr: 0xfffffff012ed0f6c fp: 0xffffffee7959fb20\n\t\t lr: 0xfffffff012dccc50 fp: 0xffffffee7959fbc0\n\t\t lr: 0xfffffff012d9fb68 fp: 0xffffffee7959fc20\n\t\t lr: 0xfffffff012db8874 fp: 0xffffffee7959fcc0\n\t\t lr: 0xfffffff012db8cec fp: 0xffffffee7959fdb0\n\t\t lr: 0xfffffff012ef484c fp: 0xffffffee7959fe80\n\t\t lr: 0xfffffff012efe08c fp: 0xffffffee7959ff10\n\t\t lr: 0xfffffff012d837b8 fp: 0xffffffee7959ff20\n Kernel Extensions in backtrace:\n com.apple.driver.AppleARMWatchdogTimer(1.0)[5133D809-B6E7-32DC-8177-6873F5C24635]@0xfffffff0136a7970->0xfffffff0136abd37\n dependency: com.apple.driver.AppleARMPlatform(1.0.2)[98A24B67-A443-3C7F-A0D6-F33C1BADF6D4]@0xfffffff01365a740->0xfffffff0136a796f\n\nlast started kext at 801246119: com.apple.plugin.IOgPTPPlugin\t1110.14 (addr 0xfffffff01267b180, size 111770)\nloaded kexts:
my iphone xr freeze and i have to force restart every 10-20 minutes, many says it’s the charging flex but can it be just software problem?
Оценка 0
8 Комментариев:
Diaz Julian, Yes, it can be a software issue. After making sure you have a good backup, use iTunes or a Mac to wipe an restore your phone. Then do a new evaluation.
из
I have been to 7 places and all of them said different things the last one said it’s probably my storage need to be replaced by a new one but I’m not sure but most of them suggest to restore the iPhone but I’m worried it will keep restarting even in recovery mode, will it happen? also, could you tell me how to backup my iPhone if my iPhone keep restarting itself? Thank you 🙏🏼
из
Diaz Julian, How often does your boot loop occur? Is it a 3 minute (180 sec) loop? If that is the case, then getting a backup can be tricky. It’s things like these that helps people realise the importance of always having a backup. I personally use iCloud and I have my iPhones and iPads backed up every night automatically. The standard iCloud account covers a phone easily (storage wise) but since I have many, many devices daily backed up, I pay for extra storage.
If you have a 3 minute loop, you’ll have to find out what’s causing the loops. Find your latest panic log and upload the text of it to SourceBin (my personal preference) and post the link so we can inspect it.
из
I’ll add this in it’s own comment, as it’s fairly long.
The first thing is to do a software restore (assuming you have a current backup)
Next suspect is a charge port flex assembly as this is a high % perpetrator
You could have I2C battery lines issue (difficult to diagnose unless you have access to the schematics and have experience in electronics diagnosing)
You should install this gem CoconutBattery on a Mac and connect the iPhone to the Mac. It can tell a lot about the battery installed, that is important to know. Battery issues can be a cause for boot loops.
из
@geirandersen Hey how to post in source bin? I don’t understand
из
Показать 3 больше комментариев
I got this problem from 4days ago and my phone keeps restarting , pleaase some insight about the problem
Оценка 0
1 Комментарий:
This is almost certainly a software issue. I have seen oodles of these with iOS 16 and more than likely you'll need to do a factory reset of the phone to correct it.
из
Please help me find out what the problem is?
panic(cpu 0 caller 0xfffffff01e4a2818): userspace watchdog timeout: no successful checkins from SpringBoard in 180 seconds
service: backboardd, total successful checkins in 5673 seconds: 550, last successful checkin: 160 seconds ago
service: SpringBoard, total successful checkins in 5642 seconds: 546, last successful checkin: 180 seconds ago
service: mediaserverd, total successful checkins in 5673 seconds: 553, last successful checkin: 120 seconds ago
service: logd, total successful checkins in 5673 seconds: 548, last successful checkin: 180 seconds ago
service: thermalmonitord, total successful checkins in 5673 seconds: 549, last successful checkin: 160 seconds ago
service: runningboardd, total successful checkins in 5673 seconds: 566, last successful checkin: 0 seconds ago
service: wifid, total successful checkins in 5673 seconds: 548, last successful checkin: 180 seconds ago
service: configd, total successful checkins in 5673 seconds: 565, last successful checkin: 0 seconds ago
Оценка 0
1 Комментарий:
Pol, this is generally a software issue, apparently it's especially bad with early versions of IOS 16. The cure is to backup your phone, do a complete restore and update to the latest software, then restore your backup and that usually fixes the problem. See Alisha's (@flannelist) excellent Kernel Panic Wiki article for details.
iPhone Kernel Panics
из
Добавьте свой ответ
Jake Bravo будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 16
За последние 7 дней: 116
За последние 30 дней: 470
За всё время: 13,790
