Выпущен 16 сентября 2016 года. Модель 1660, 1778. Стандарты связи GSM или CDMA. Память 32, 128 или 256 ГБ. Цвета: розовое золото, золотой, серебристый, черный и глянцевый черный.
2188вопросов Показать все
think that I broke the display circuit
Hi Rany,
Regarding the answer you wrote, I think that I broke the display circuit on my i phone 7.
When I changed my screen, I tought my phone was switch off but it wasn't. Now when I plug the old or the new screen, it doesn't display anything but I can feel that the phone is still swich on. Do you think the piece of the phone I broke up is the display circuit? Can I change it? Do you know some tutoriel maybe ?
thanks for your help!
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
Наиболее полезный ответ
did you disconnect the battery first
Был ли этот ответ полезен?
Оценка 1
2 Комментариев:
no I was an idiot and didn't realise about this.
I didn't do it first time and was ok.
Second time just to fix home button didn't either and now the problem
Can this be sorted or have I fried the screen?
из
shine a light on the screen to see if you have image, you could have possibly blown a backlight filter by not disconnecting the battery
из
If the home button feels like the phone is on and you didn’t disconnect the screen to work on the home button I bet you damaged a screen ribbon.
Turn the phone off. Disconnect the battery then disconnect everything else. Make sure the home button is seated and connected properly and the plate is fitted. Reconnect the ear speaker flex and the screen and home button connectors then finally the battery then try it. If the home button works and the phone vibrates when you flick the mute switch then I’d say it was a screen issue. If you didn’t disconnect the screen and battery whilst working on the home button I doubt it would cause a back light problem.
Оценка 1
Добавьте свой ответ
zac будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 17
