Why my Xbox don't pull the disc into itself
My Xbox don't pull the disc
Это хороший вопрос?
Это хороший вопрос?
Hey, I don't know if you have solved the problem yet, but it is definitely an issue with the disc drive in the Xbox. You would need to order a new blue ray disc drive and replace the broken one in your Xbox. You need to take the old PCB out of your disc drive and put it in the working new one. This does require soldering so your gonna need a soldering iron.
You MIGHT be able to fix the actual disc drive instead of replacing it, but I find replacing it way easier.
Here's a guide incase you want to try to fix it: Xbox One Disc Drive PCB Replacement
Был ли этот ответ полезен?
За последние 24часов: 2
За последние 7 дней: 3
За последние 30 дней: 3
За всё время: 26
