iPhone 11 restarting when audio is played
Hello, yesterday night I droped my phone in the shower and it got a little bit wet, though everything worked normally.
This morning when I woke up I found out that the phone keeps restarting when audio is played. So the phone will work normally until I try to play a spotify song or a youtube video etc.
I don't trust the phone not bricking itself if I try to restore it, do you have any advice on how to handle this problem.
Kind regards
Это хороший вопрос?
Checking diagnostics I found that there are several files dated today that show AOP PANIC - No pulse on 0x11200e0 - main(5). Though I am not sure of what does it mean.
из Pablo
Bluetooth audio works, phone calls work with top speaker, but bottom speaker does not work on phone calls, though I did not experience a reboot
из Pablo
@willmontaraces can you post the actual panic? Even the first screen's worth of text is usually helpful.
из Alisha C
@flannelist I tried to open up the phone and seems like I applied too little heat and broke the screen, now I have a iphone that restarts itself and with a broken screen. I think it is too expensive now to repair and it is worth it to buy another one. Thanks for your help
из Pablo
Sounded like you needed a new charging port assembly. The speaker and microphone are located on the same ribbon. Before you broke the screen of course.
из [deleted]
Показать 1 больше комментариев
