Released in May of 2019, the Xbox One S All Digital Edition (model number 1681) is a revision to the Original Xbox One S (released in 2016). This model of Xbox One S ships with no Blu-Ray Disc Drive (thus there is no disc slit at the front), exclusively providing downloadable and streamable entertainment.
23вопросов Показать все
Xbox want turn on and took it apart and cleaned it and didn't see any
Xbox one s all digital want come on or anything
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
Does it come on into safe mode? Hold the sync button and press (and release) the power button.
If not, have you tried replacing the power lead? I’ve seen a few faulty ones. Ask a friend if you could borrow theirs to test
Был ли этот ответ полезен?
Оценка 0
Double check all of your connections to make sure you don't end up doing unnecessary repairs. It's easy to not plug something in right. It's not likely, but there is also a chance you could have knocked the power button off the IR blaster daughterboard. I did this during a repair, and I came to realize how easy it was to knock of the tiny little buttons. A way to test this is to listen or feel for a click when you press the power button. If it is broken, here is the part you will need to fix it: Xbox One S RF Board and IR Blaster
Xbox One S RF Board and IR Blaster Изображение
Продукт
$19.99
Оценка 0
Добавьте свой ответ
Frankie Loveless будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 12
