2012, 2013, 2014, 2015, 2016 Scion FR-S models. Also known as the Toyota FT86, the Scion FR-S is a sports car which was jointly developed by Toyota and Subaru. It has a 2.0L 4-cylinder engine with a 6-speed transmission.
1вопросов Показать все
abs,traction an dbrake light on
i took it to Miata Toyota they said is the abs relay i changed the abs pump but still the same lights on help please!
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Over time, the relay contacts become carbon-ed up. You can either change the relay with a new one or cut the top off carefully and pinch a thin business card between the contacts and draw it through there until no black trace comes out onto the card. Do not use abrasive paper or a file. I believe the relay is located separately from the pump, so changing the pump won't fix the relay issue. I used to repair ABS modules ... they blow the earth track internally as a very common problem; an easy fix. Failing that, it can be the ABS computer, but I'm assuming they checked there was a good signal to the relay first.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
hai hoho будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 24
