George:
U need a "special" adhesive tape, a thin one, as the kind used for iphone 3GS touch screens.
Or you can buy another kind, it just have to be thin, STRONG and double sided!
What you do is: Cut the adhesive so it fits metal fram, NOT covering the sensors around the top.
After doing so, u fold the flex cables as they were on the old part. There should be some adhesive already on the LCD flex cables, that needs to be removed.
When thats done, you remove the coveredge on the doublesided adhesive tape, and place the touch + LCD firmly on it, now, press and hold for about 30seks, till you belive the touch is holding, mind the corners, press here also!
THEN your done, assemble the phone again, close your eyes and press the power button, hopefully your "lucky" and you got a picture on the screen hehe :D Good luck mate.
contact me on Skype: CRATERHEAD
Best Regards
Apple Repair Herning DNK
Palle Skov
Был ли этот ответ полезен?
Проголосовали
Отменить
Оценка
0
Отмена
Scroll through this thread to find the appropriate place for this comment. Then, click "Attach comment to this post" to move it.
Why ppl are selling touch screens only, is because they make money that way.
I did this mistake the first time aswell, but i soon realised that those two parts coudnt be separated.
I told my seller of the touch screen what a "wa**er" he was and requested a FULL refund. I sent the touch screen back and got the refund as reguested (i did mention a very negative feedback on ebay, and the seller was suddently very Cooperative).
Again, contact me if you need any help. Skype name above :)
из ArHerning
Hey dude...Thanks for the reply...so, I finally got changed LCD plus Touchscreen Digitizer replaced today. Now, my story: I got it replaced. Everything is working fine. Touch qualtiy is same as before. So, no issues. But the mechanic I gave my handset to was a newbie. He did best though but was not able to perfectly fit in. As a result, my touchscreen digitizer is coming up from its position a little. Just a press around home button and it sets in. But that solution is jus temporary. i think I would need some tape or glue to fix that. Any insighst guys..I have attached three images along one of each side view to give u a better idea. Thanks..:) for images, visit here: https://plus.google.com/photos/107735609...
из manjo3311
The same happened with me :(
из Emanuel Costa
