Why isn't my brake lights working
I check all the fuses, and when i turn my lights on they come on but when i step on the brakes the lamps don't get brighter, also when i step on the brake it does not make that click sound for my shifter to work so i have been using the shift lock release button
Это хороший вопрос?
3 Комментариев
khalif, you should combine both of your questions. It looks like they have a common fault.
из oldturkey03
I replaced switch, didn't help. I have a manual, it also controls is the cruise but that works fine
из David Anderson
man let me answer u r question as happen with me .
my car is honda crv 2001 and my horn dosnet work and shift and lights too dosnet work and when i changed fuse i think it was number 15 may be not sure .
из peterpeterko
