Missing TG0B causes kernel panic, plus fluctuating battery level
The problem began 2-3 weeks ago while the device was charging.
Reboots are not spaced evenly at 180s apart, which probably indicates the sensor is responsive at times and not at others? At the beginning of the issue, I could sometimes use it for 5-10 minutes without rebooting, and sometimes less. Charge level fluctuates around 10-20% on each reboot and just randomly when unlocked. The reboots got more frequent and regular over time. Last night it seemed the iPad was charging very slow.
I took it for repair today,
They replaced the battery and the issue persists.
I've read TG0B is an NTC thermistor in the battery.... what could be the next steps? Any possible issues in the measurement circuitry?
panic(cpu 0 caller 0xfffffff0243a0514): userspace watchdog timeout: no successful checkins from thermalmonitord service returned not alive with context : is_alive_func returned unhealthy : current 1ffffffe, mask 1fffffff, expected 1fffffff. EC: 1 EH: 3758097110 3758097110 SD: 0 BC: 0 RC: -1 BS: 0, Missing sensor(s): TG0B
Это хороший вопрос?
1 Комментарий
This might be a late reply, but I had this error in my Wi-Fi iPad 7 as well after doing a logic board swap. I was able to use it for about 1-3 minutes after boot before it would kernel panic and restart. Turns out I forgot to fully screw in the battery, which likely caused a weak connection between the pins. If you could, try opening it up and just seeing if a battery screw is present. You might need to use a screw from a for parts iPad or take one from the upper bracket by the cameras.
из ErnieIsABird
