1.6 or 1.8 GHz dual-core processor, 2 GB or 4 GB of SDRAM, 64 GB or 128 GB SSD
189вопросов Показать все
MacBook Air 11" refurb: Upper Case + Track Pad Q's
I'm going to try and do a sort of refurb on my old 11" macbook air 2011. One of my kids "cleaned it" with a spray air freshener and now the keyboard is shot. It's also had a bad track pad for a while now.
Question is, I'm going to try and replace both parts. What parts, beside the pad itself and the upper case, if any will I need? Also, what size/type screw drivers, will I need? I have a P5 and a T5 but I'm already into the process and can see I need something larger for disconnecting the display.
Any other tricky considerations?
Thanks!
Это хороший вопрос?
Оценка 1
Добавить комментарий
1 ответ
Наиболее полезный ответ
Hi
If you are replacing the trackpad and top case you will need a top case with a keyboard backlight if the old one doesn't work(if it works you can just go around the edges to loosen it up and transfer it over) and you will need to transfer the old trackpad cable over to the new one
Heres the guides you will need for these repairs
Top case
MacBook Air 11" Mid 2011 Upper Case Replacement
Track pad
MacBook Air 11" Mid 2011 Trackpad Replacement
As for Screwdrivers and tools I recommend one of iFixits toolkits, they will last you a lifetime and have the majority of the bits you need for most repairs and I can say this from experience and in confidence
Heres on that should do the job for you:-)
Essential Electronics Toolkit
Hopefully this helps
Any questions please ask
Essential Electronics Toolkit Изображение
Продукт
$29.99
MacBook Air 11" Mid 2011 Trackpad Изображение
Инструкция
Сложность:
Модерировать
20 - 40 minutes
MacBook Air 11" Mid 2011 Upper Case Изображение
Инструкция
Сложность:
Сложно
2 hours
Был ли этот ответ полезен?
Оценка 2
Добавьте свой ответ
trey meadows будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 25
